How do you get Voice Mail notifications?
snoops988
I been recieving Voice Mail messages without me knowing about them.  Is there a way to recieve a notification via text or something?
kav2001c
@snoops988 Public never offered voice mail to txt, but there are 3rd party apps you can get to do same thing.
In iPhones, you'll see a red dot (button notification) when you're inside your phone app.  The dot will stay as long as you have a voicemail sitting in your inbox.
Chaos_Scorpio
andriod - go to phone app - 3 dots - settings -  calls -  voice mail - turn on vibrate and sounds if you want.
apple no idea there
Chaos_Scorpio
They should be automatically done... as soon as a recording is entered you get the recording icon in the tray (and a notification if you have it on).
What phone do you have? Maybe you disabled the feature?
