How do i find a sim network puk?@
SamP25
2 REPLIES 2
HALIMACS
@SamP25
What is the message you're getting?
If you're getting:
 "SIM network PIN blocked. Enter SIM network PUK." on a Samsung phone then call Samsung at 1-800-726-7864 and they will give you a code to unlock it. They'll want the IMEI of the phone in question.
If any of these:
  • "SIM network unlock PIN"
  • "SIM ME lock code NP"
  • "SIM not Supported"
  • "SIM locked"
  • "Network Unlock Code"
  • "SIM PUK code
  • "Network Control Key"
  • "Master Unlock Code"
  • "Network PIN",
These mean the phone is locked to a previous provider. You'll need to contact them to unlock the phone.
If any of these:
  • "PIN unlock key (PUK)"
  • "Enter PUK Your SIM cannot be accessed"
  • "Locked SIM"
then contact support:
