How do I turn off voice mail completely?
musicollector
TIA.
1 ACCEPTED SOLUTION
Accepted Solutions
@musicollector  you can't .. but there is workaround;
to "disable" voicemail, on your dial pad dial: *004*8080000000#
This will cause all calls to either ring forever or get fast busy at the point they normally would have been diverted to the voicemail system.
To reset it back to defaults, dial ##004#
NDesai
@musicollector You cannot. However, you can disallow callers to leave voicemail.
See here: https://productioncommunity.publicmobile.ca/t5/Get-Support/Re-Disable-Voicemail/m-p/213805/highlight...
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
popping
@musicollector
We cannot turn off voicemail.  But you can setup your voicemail not letting caller to leave your a message.
Follows the following flowchart to create extended absence greeting and don't let caller to leave message:
[3]Greetings --> [4]Extended Absence --> [2]Record
[3]Greetings --> [4]Extended Absence --> [5]Message not allowed after greeting
[3]Greetings --> [4]Extended Absence --> [4]Turn On
Timer
musicollector
Wow! EXACTLY what I was looking for. THANK YOU!
musicollector
Thanks to all who stepped up to help. Cheers.
