How do I get a ticket?
Colls8
Hi there,
thank you
2 REPLIES 2
Colls8
Thanks very much 🙂
hi @Colls8
you can try to post the question here and community members will try to help
But if account problem, yes, best to ask support agent directly
  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
