How do I find my Community user id number?
Tsawwassen
13 REPLIES 13
Tsawwassen
Thank you it was hidden in plain sight -----It's a simple method to edit ones photos - your id is 162890
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/162890/tab/all
Hi @Tsawwassen
haha.. yes your profile page URL has a number and that is your user ID nomber
https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/133677
but why you need it?  it is not useful unless you are programming something.
dust2dust
Click on any username which will open their viewable profile. In the address bar at the end of the url is the numeric userid. User Tsawwassen doesn't have any images. This is the link to their images.
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/133677/tab/all
Tsawwassen
You're playing me - ha ha  - again where does one find these id numbers - You obviously are knowledgeable on how to find them.
Hi @Tsawwassen I think either you didn't logoff properly when you switch from Beer to your account, or you havr too much 🍺 after the losing Canada Worldcup game..
Beer user ID # is 62124
Tsawwassen
No when I input 133677 it brings up BEER account. Again where did you locate this number - I did include random numbers in a string and it brought up other member accounts - example below -
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/46317/tab/all
Hi @Tsawwassen  I was correct, I didn't mix up with your other family members IDs
your own Community user ID number is 133677
User ID number is a number,  not string
Tsawwassen
No That is not my user id number - can you please give me the correct one. And how are you able to get this information?
Tsawwassen
Where did you find my user id number ?
I perused my settings and could not find it -- where should I look?
I was given a string and apparently one can just put anyones user id number and go to their public account.
Hi @Tsawwassen
you od # is 133677
your user name here is Tsawwassen
don't get mixed up with your other family accounts
Quigley
@Tsawwassen    Just look at the screen, right in front of you. Hello 🤗
mitchnet12
@Tsawwassen  Tsawwassen appears to be your user id in the community.
Metal1967
@Tsawwassen  You’ve been using  it….
