06-16-2026 01:53 PM
06-16-2026 02:17 PM
if you wish to keep the cell number, just transfer the number to your new cell provider. Once you've successfully ported to new provider, your Public Mobile account is automatically deactivated.
If you're just done with your cell in Canada...follow directions supplied by softech.
06-16-2026 02:00 PM
there is no contract with Public Mobile. Your service is prepaid and it is monthly by month
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
Or if you cannot login My Account to disable Autopay,you can private message CS Agent and ask them to remove the credit card from the system:
