How can you find your PIN number?
ruif71
Is there a a place that has your PIN # listed on your Profile Account?
I can't remeber what I set up as my pin.
8 REPLIES 8
ruif71
I sent a private mesage to the Moderator Team and all is good.
Easy.
cavemantoronto
Great you found it in the text.  It is not listed in your self-serve account anywhere.
ruif71
Just saw that 611 message.  Thanks!
popping
You should have received 2 text message sent by "611" right after activation.  Both text messages contain a PIN number.  IDK where PM got the PIN from the fitst text message.  The second text message is the PIN number which I entered during activation.
Check your text messages on your phone around the date you activated your PM plan.  I hope that you have not deleted those text messages.
@mimmo wrote:
If none of the above work send a message to moderator_team and ask them to reset your pin.
It's already posted 😉
mimmo
Lieux
Your pin was written in the first messages you received from public mobile if you still have them..Smiley Frustrated
Someone_here
If you are talking about account PIN
No it is not written anywhere... except:
  • In your signup email if you still have it 😉 (thanks @Lieux for confirming this)
  • In a text message (probably the second one) sent from "611" right after you activated your line (thanks @ruif71)
If you don't have your email/text anymore, then you can message the mods and ask them to reset it.
Related topic with approved solution:
https://productioncommunity.publicmobile.ca/t5/Self-Serve/How-do-I-reset-my-4-digit-account-pin/m-p/...
If you are talking about voicemail PIN
Then you can reset it in your selfserve account 🙂
(edited to get all answers in one place ;), thanks to @Lieux  and @ruif71 for the added information!)
