04-01-2019 09:46 PM - edited 01-05-2022 04:06 AM
Hello to all.....i've just changed plan from $20 to $25 it said needed to top up I did
when is new plan to effect ..still saying or Showing old plan,, did a search can't find an answer....only for 3 g for 48 hours... but no 3g for I.....just change of plan...can anyone help me , i want the plan to be On at this moment..........Thank you ,,,,,
04-01-2019 10:37 PM
@irishman4 wrote:computergeek541 I know what i was doing , it just i wanted to take in effect today...but as you mentionned why loose 2weeks.....next cycle will start the april 15th ..all plans starts the 15 each month ....!!!! of what i see in my account...so that's perfect...i'm retired Now...
Got all the time in the world , to wait for a tiny 2 weeks ...thanks for your help............
next cycle starting april 15th ..balance as right now $ 0 which means i'm good still the 15th on the old plan...................................Regards.................
Since Public Mobile's plans have a 30day duration but some months have more (or less) days, your payment date will move around and will not always be on the 15th.
For several reasons I would still future date that plan change now.
a) Life can get busy or complicated, you might forget to do the change in time...
b) Muddling around in your self serve account on renewal day can potentiallyy mess up the system. General consensus is to stay away from your account during renewal as to not be tempted to intervene or being freaked out by all those weird messages in the funky process.
c) If you are intending to switch to a Special Offer plan, there is a minimal chance that it is pulled before your renewal date. If you have a future dated plan change to a plan that is no longer offered your account will still change to it.
04-01-2019 10:14 PM
04-01-2019 10:05 PM
@irishman4 wrote:Hello thank you....so Better to keep the old one 'till it ends... thanks will accept as a solution & wait 'till april 15th....other reason if a change it....like you said , will loose what's left of my $20 plus new $25 payment is Now....and all payments will be sooner....as well ...
So i'll wait 2 weeks...............................Regards............will click accept as a solution + Bravo
.................................Good Evening..................................
I would still advise for you to log into your self-serve account and double check to see if that is what you've actualy done since it sounds as if you originally weren't sure what was going on with your account. If you go into the change plan section of your account, it will show you details about any scheduled plan change if that is what is set to happen.
04-01-2019 10:01 PM
04-01-2019 09:51 PM - edited 04-01-2019 10:02 PM
@irishman4 wrote:Hello to all.....i've just changed plan from $20 to $25 it said needed to top up I did
If your self-serve account is still showing your old plan as active, this likely means that the plan was set to change after your current 30 day plan is over, and when it would have otherwise renewed.
If you want, you can remove the future-date change from within your account. You could then set the plan change to take effect immediately. However, please keep in mind that if you do that, you will lose whatever you have already paid for the $20 plan, any usage that was remaining on it, and your new $25 plan would take effect immediately with the full amount also being due.
