6 hours ago
4 hours ago
You will need to buy an international sim or esim. PM does not provide service outside of CAN/US zones.
5 hours ago
@Hoojeygo, Public Mobile does not have roaming options outside of Canada/US so you would either need to get a SIM card where you will be OR If you have access to WiFi you could use apps like WhatsApp, TextNow or Messenger etc.
6 hours ago
You can’t, unless you’re in US and have Canad-US plan or IS roaming add-on
PM doesn’t have any roaming services outside US
