How can I porting my number from Bell?
sophitechnicusñ
Hello,
Thanks
7 REPLIES 7
sophitechnicusñ
Thanks ....
I'm alredy in the network.
I'm asking for another persons that try to to check the option before do action ..
The my conclution .... it's necessary to improve a lot of things about informations for the new people they want ..... but they not enough info ...... no comment .......
sophitechnicusñ
In my opinion neded to be in section:
https://www.publicmobile.ca/en/qc/get-started
All the new people red here .... nobody try to find a solution at the first time.
Try to be firts time on this web site. This is the defference ......
Thanks but thinking ......
sophitechnicusñ
I know,  it's normal.
Thanks
popping
@sophitechnicusñ
Make sure that your Bell number is active as you cannot port number which is not in service.
sophitechnicusñ
Hello,
Thanks, I hope to be so easy.
I supposed.... on web site I didn't find this info.
mimmo
Loginto self serve click plans then click change number. From there you have the option to select a new. Number .or port an existing number.
You need your account number, and name on account as on bill.
