How can I keep my number and plan?
02-01-2019 09:41 PM - edited 01-05-2022 06:35 AM
I need to leave canada for more than 3 months and how can I keep my plan and number without paying full payment? thanks
Service
02-03-2019 09:48 PM
@Dankaroo wrote:
@mimmo wrote:@zmh1175 when does your plan expire? When are you leaving?
When are you coming back
What plan are you on?
Answer those questions and we can help out.
But if you want to keep your existing plan you need to renew before the 90 days pass.
No need to contact mods.they will say same thing.
Edit this is a good read.
I found this very informative, quick question if I may. Does changing plans effect the regularly accumulated rewards for let's say referrals?
No changing plans does not effect rewards.
except i believe sometimes when changing from a 90 day to 30 day. The system might get confused and not give you the correct mulyiplier.ie x1 instead of x3. But mods will adjust if needed.
02-03-2019 09:36 PM
02-02-2019 01:38 AM
@zmh1175if you leave it for about 80 days after it's expired you can renew it once online and that will reset limit, rather than pay it every month.
02-01-2019 11:22 PM
@zmh1175 wrote:I want to keep my old plan
If its the plan that is currently not available, you must renew that plan before 90 days of expiry or else you will lose your account and your number.
02-01-2019 11:21 PM
02-01-2019 09:55 PM - edited 02-01-2019 09:58 PM
@Alex888 wrote:
You would have to talk to a moderator here:
Why does OP need to talk to a Mod?
@zmh1175 You let your plan sit on expired/suspended status for no more than 90 days. When you nearing around 88 days, you can switch your plan to cheapest $10 just to renew your account. When that plan expires in 30 days, you have another 90 days.
So depending on how your account is set up in terms of payment method, we can advise you what to do. For example, if you are on AutoPay, your plan will auto renew so you need disable AutoPay. If you have enough balance in your account, your account will also auto renew. But this can be stopped by using the lost/stolen feature.
Let us know if you have any further qs.
02-01-2019 09:53 PM - edited 02-01-2019 09:55 PM
02-01-2019 09:44 PM
You could switch to the $10 plan to keep your number.
