How can I issue a refund for an Add-On that didn't work in USA?
loebproductions
I purchased a USA roaming package for my trip to Alaska and there was no service the entire time. I couldn't make any calls, texts or use data. What is the best way to get a refund here? I found out after the fact that Public Mobile doesn't work in the state of Alaska now, while it did last year. Thanks so much.
2 REPLIES 2
maximum_gato
@loebproductions
Unfortunately US Roaming no longer works in Alaska until pm renews its roaming partnership with AT&T. Until that occurs the best provider to use in Alaska is CGI. Ask for a credit to your account (refunds take up to 30 days to be processed back to your card) from customer support using the links supplied by @dabr.
dabr
@loebproductions   You'll need to submit a ticket to customer support via chatbot and request the refund (account credit) via this link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Or send a private message to CS_Agent if unable to submit the ticket here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
