01-17-2020 03:39 PM - edited 01-05-2022 09:04 AM
How can I change my username in 'community' - thanks!
01-17-2020 06:46 PM - edited 01-17-2020 06:49 PM
@ChuckYeah wrote:@will13am Can you see that option? I just changed mine a couple of weeks ago, and I was not able to change it myself at that time.
I wouldn't know that this was an Oracle-only setting myself unlesss I had looked around the settings before as a non-Oracle. The Community account doesn't advise us of it being an exclusive option.
01-17-2020 04:51 PM
My bad, it is an elevated priviledge that I have. Sorry for getting everyone's hopes up. Contact moderator is the solution.
01-17-2020 04:43 PM
To contact a moderator, create a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand (e.g. no service, can't send texts, can't call out or no data).
Answer Simon's questions until you get here:
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours: Monday-Friday: 8AM- 12AM EST; Saturday & Sunday: 8AM-10PM EST
01-17-2020 04:43 PM
I agree/
01-17-2020 04:42 PM
I agree. Not possible through settings/personal
01-17-2020 04:41 PM
Thanks, for the reply, but just stating that this doesn't work. In case anyone else reads.
I believe it can only be done by moderators.
01-17-2020 04:01 PM
The moderator I dealt with sent me several messages telling me how to change it and I thought I might be the issue. But in the end, we agreed that feature must have been blocked at the user level.
01-17-2020 04:00 PM
Yes @ChuckYeah is right, you'll have to contact a moderator. There is no option in setting to change your username. The only thing you can change by clicking your avatar is personal info.
01-17-2020 03:59 PM
Sorry @will13am I don't see any option either. You are probably thinking of something else.
I believe @ChuckYeah has it right.
01-17-2020 03:53 PM
01-17-2020 03:49 PM
@martihopson, when you are signed into the community forum, click on your avatar on the upper right corner, select my settings, personal. You will see the option to change the name there.
01-17-2020 03:41 PM
@martihopson Send a ticket to @CS_Agent . Only they can change it for you.
