04-10-2023 03:33 PM
04-10-2023 03:51 PM
first ensure you have the numbers correct on your SIM card and if you have them correct you can,
contact costumer support by submitting a ticket to them and they will be able to help you
04-10-2023 03:37 PM - edited 04-10-2023 03:40 PM
Where did you purchase the SIM?
It might be previously activated.
Best thing to do is to contact a CS_Agent by submitting a ticket on the bottom of page or private message them on the envelope icon above to confirm if it hasn’t been previously activated.
04-10-2023 03:36 PM
Please double check the SIM card number as it is very easy for anyone to make a mistake when typing in a long sequence. If that still doesn't work, check to see if it is a new and unused Public Mobile SIM card as they can't be re-used. If the SIM card number still doesn't work on the Pubilc Mobile activation website, you will need a new one.
