Honor 8 (FRD-L04) - Signal Issues
CTWAU
Previously had an iphone 6 and it worked fine with PM. It was broken so I replace it with Honor 8 from newegg.
I checked the model number : (FRD-L04) seems to have the right bands for LTE and everything else.
However when I start using the phone I usually cannot connect to LTE, do text messages or call out. (It only works 5-10% of the time)
Any idea how to resolve this issues I am not sure if this is a hardware issues or if it is a software settings issue. I have already adjusted the APN settings to what it should be.
All advice would be greatly appreciated.
CTWAU
I ended up trying the SIM ona  working Iphone 6 and it seems to be working on that phone fully.
I went back to my new phone and did some changes to the APN settings and the situation seems to be improving. ( i now have data and text more like 60-70% of the time). I changed the name of the APN.
Before it was switching between full services and no service
Samianauman
Phone frequencies looks fine
Technology GSM / HSPA / LTE
2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3G bands HSDPA 900 / 1900 / 2100
HSDPA 850 / 1700(AWS) / 1900 / 2100 - AL00 (USA)
4G bands LTE band 1(2100), 3(1800), 7(2600), 8(900), 20(800)
LTE band 2(1900), 4(1700/2100), 5(850), 12(700), 17(700) - AL00 (USA)
Speed HSPA 42.2/5.76 Mbps, LTE Cat6 300/50 Mbps
GPRS Yes
EDGE Yes
Try this take sim out turn off phone insert sim restart if that doesn't help also try factory reset and also check LTE network is on if that's doesn't help then as other op suggested try sim in different phone this way you will find out if its service or hardware issue if its service issue then you can contact mod if you see same issues in other phone
If you don't know how to connect with mod dept here is how
But try other suggestion first before getting mod involved to investigate your issue
Contact mod dept they will help you with the process
In your private message to any moderator include whatever bits of the following info you have:
* PM account email address
* PM phone number
* Detailed explanation
* Community Moderators are available from Mon-Thursday 9am(EST) to 9pm(EST) and Friday, Saturday, and Sunday from 9am(EST) to 5:30pm(EST)
Here is the link for how to contact moderators http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updiated-Contacting-our-Community-Moder...
** I am not a Mod, please do not include any private info in a private message to me.**
mimmo
best way to check is try sim card in a different phone.  if issues persist then its a sim card problem.  if not then there is  problem with your phone or a setting issue.
