Hi, Looking for referral code/ fix texting
mesopotamian
I recently joined and have been unable to receive text messages. Additionally, I would like to refer my wife in order to receive a discount, but I'm having trouble figuring out how to do so.
Rastin
I just saw a new post about the ongoing problem with text for new customers and they Suggested doing this.
manually select wireless provider as public mobile.
Don't know if it will work but Worth a try. You will need to Google how to do it with whatever phone you have
kevin888
same trouble to my wife's . the way you can try is manually select  wireless provider as public mobile. if it does not work you may open a ticket. it works to me.
Rastin
The referral code can be found under account in your app
Rastin
To fix texting you will need to open a ticket using chat bot the little text box on your bottom right hand corner. And tell them your problem. Will take about a day to get a response.
