11-06-2022 09:03 PM
11-06-2022 09:41 PM
@Jkozjak wrote:Ok thank you I see that it shows plan change in Decemberbon next renewal and will ride out my current plan until then.
@Jkozjak yes, given that no partial refund on unused days and no rewards will be applied for early plan change, leaving to the upgrade on the renewal date is the better choice 🙂
11-06-2022 09:39 PM
11-06-2022 09:38 PM
Thank you
11-06-2022 09:07 PM - edited 11-06-2022 09:08 PM
@Jkozjak Yes, text reply upgrade plan will schedule the plan on next renewal date
If you want to do it earlier, please remember there is no partial refund to the unused days and data with the current plan. Also, if you choose to upgrade the plan early , you will get charged the full plan price without applying any reward for this one particular time.
If you are ready to do so, please login to My Account, go to Plan and Add-on page, then choose Change my plan, then pick the correct $40 plan (there are two different $40 plans under 4G section), and then select Change plan now
11-06-2022 09:06 PM
@Jkozjak You can go into your account and do an immediate plan change, it will charge right away 40$ no refunds for partial previous plan
