Hi, I put WRONG IMEI to get new plan....
Sangwoo
I tried to contact, but it does not work.
What can I do? just now I sent msg to cs agent.
I want to call someone but I couldnt find number!
2 REPLIES 2
@Sangwoo  No worries I’ll send you the porting team number private message . and just give the old providers account number and ignore the IMEI it’s not needed anyways and they will re trigger the port request for you
hairbag1
@Sangwoo
there is no number to call...everything is dealt with either here in Community or the Customer Support that you already messaged.
