Hey
Hellemhalbych87
How do I setup my voicemail?
7 REPLIES 7
Thanks @mh1983 and @Pizzaeh for sharing!!
mh1983
Two ways:
1. Highlight your text and then click the link chain icon (insert/edit link), then add the URL for the website.
2. When replying to or starting a post, you can switch to HTML view and add the code yourself for an href.
Pizzaeh
@Lieux wrote:
@Pizzaeh wrote:
Hey...Voicemail
How do you do that..? Smiley FrustratedWriting voicemail and it's a link....? Thanks
When you click the 'Insert/edit link' icon, it brings up the window to enter the URL.  Below that, there is a field for 'Text to display'.
@Pizzaeh wrote:
Hey...Voicemail
Pizzaeh
Hey...Voicemail
hairbag1
See the orange ball with question mark on right side bottom of page. Click and type voicemail set up. Follow instruction. Good luck and welcome to Public Mobile.
wordup41
Hello,
Go to your phone dialer and hold 1. Follow the instructions after.
