Help
WadeDawe
Just bought a new SIM card set up account and cannot add payment voucher to activate phone , please help
@WadeDawe
You can setup the payment section with a CC then disable AutoPay and use vouchers as payment in the future.
WadeDawe
Thanks so much just sent agent message I hope this works
@WadeDawe
You can use your voucher   to activate  but not on the Activation portal directly. It involves a bit of work:
  1. Open ticket with PM support by direct message them:
  2. PM support reply and ask you for the sim card number, an email address used for the activation (login for My Account).
    They will activate the account with the sim card.  The account will have status SUSPENDED.
    PM Support will then sent you the login and password.
  3. Once the account is setup, you can login to My Account and load your voucher to finally activate the service.
