06-07-2022 01:12 AM
06-07-2022 01:35 AM
If you want you can provide some more info on your issue and it may be able to be easily and quickly resolved.
06-07-2022 01:28 AM
Please note CS_Agents are available between 6:00am to 10:00pm EST.
Community members here can help if it is a simple fix. So can we get more details of your problem?
06-07-2022 01:24 AM
Here on the community portal there are several very helping and experienced folks so post the details of your issue and you will get the best possible solution.
If it can only be resolved by support agent then you have got the way to contact them in above post.
06-07-2022 01:19 AM
@Leemervyn wrote:Need a agent
Customer support agent are contacted through https://widget.telus.tiia.ai/publicmobile/publicmobile.html . What type of question did you have? There are times when issues don't end up being account issues and someone here might know the answer to your question.
