Help !
aarondebow
I’m with public mobile and I I’m getting. Telus on on my settings in my page and I can call but can’t use my data at at all and I’ve seen ob my top of my screen Telus and it’s been switching back and forth now
12 REPLIES 12
darlicious
@aarondebow
If you have already connected to iTunes and updated your carrier profile and have the iOS 15.4 beta version and do not wish to downgrade to iOS 15.3 here is the fix for the data issue with the beta version.
Fix for iOS 15.4 (19E5209h) Data issue - Community
https://productioncommunity.publicmobile.ca/t5/Get-Support/Fix-for-iOS-15-4-19E5209h-Data-issue/td-p...
pkaraa
If only data is not working on your phone then it is iOS 15.4 beta issue. Downgrade will solve this.
If you see Telus and Public as your network then change your selection of network from automatic to Public as described. Reboot.
@aarondebow
Try going to your Settings>Cellular >Network Selection> turn off Automatic then turn back on.
See if that works for you.
@aarondebow
If still not working properly,
Might want to try network reset of phone.
Try the PM SIM card in another phone.  To help determine whether hardware setup issue versus PM service problem. Then put back in your original phone.
Update IOS (not to 15.4 Beta though)
Coreyb
Have you recently updated to the IOS 15.4 beta ?
VIP_Tech
@aarondebow
manually select network carrier,
go Settings → Mobile Data → Mobile Network → the indicator next to "Automatic" turn off the function → the required network → select public mobile.
and Rebooting device..
VIP_Tech
@aarondebow
your Call SMS  Data, working befroe fine ?
VIP_Tech
@aarondebow
do you do any update ios version ?
Log In Self-Serve, and check any left data,
maybe you use all data then is will be stop until next renewal cycle,
aarondebow
I have an iPhone XR I did switch my number over a mouth ago now but this is just tdy I’ve been seeing Telus on my phone
VIP_Tech
@aarondebow
what your brand device and model ?
are you activate new line with new number or you did transfer old number to PM ?
aarondebow
that has not worked any other thing to try
VIP_Tech
Hi @aarondebow
try reset your APN Settings (publicmobile.ca)
and Rebooting device..test it.
