11-01-2018 02:35 PM - edited 01-05-2022 06:02 AM
03-11-2019 05:16 PM
@RobertQc wrote:What is redoning?
@CellGirl wrote:redoning my computer never works well 😉
@Kevster1974 wrote:Try redoning on computer
haha
03-11-2019 05:07 PM
Redonner ..in french?![]()
03-11-2019 05:02 PM - edited 03-11-2019 05:05 PM
Oh probably "re-doo-ing" miss spelled, not "re-dough-ning"
After googling it I thought for sure not "red-don-ing" as in changing color to red.
03-11-2019 05:00 PM
What is redoning?
03-11-2019 04:58 PM
03-11-2019 04:50 PM
If you need help..we need some more details of your problem @Kevster1974 ..What happened?
I think kevster1974 was trying to be helpful but then typed in the tags box rather than the text box.
03-11-2019 04:38 PM
03-11-2019 04:37 PM
03-11-2019 04:37 PM
11-01-2018 02:38 PM - edited 11-01-2018 02:39 PM
@BD89 wrote:Yes I just topped it up at Walmart
Have you checked your self serve?
Did you miss your renewal date and have it suspended?
EDIT: Try this https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
11-01-2018 02:38 PM
@BD89, are you able to check your account and confirm that it's in active status? Have you tried rebooting your phone? If everything is in order but your service is still not working, I suggest seeking moderator team assistance. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
11-01-2018 02:36 PM
