Help
kellisha2
I have being getting this error since yesterday when I try to call my  mom is give a error saying b1 something  the call cannot be completed please check the number again mom.
If she calls me is okay, but I cannot call her
edited by computergeek541: changed category label as this discussion isn't related to Community
7 REPLIES 7
Mxt
I have the same problem as you.
slusagm
What model of phone is that?
slusagm
what model of phone you have? Not sure if it is a problem with VoLTE
@kellisha2
please try reboot the phone and reset network settings
if issue persists, you can ask PM CS agent to reprovision the account
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
    (if you cannot receive 2FA via SMS, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA)
Dunkman
@kellisha2
Does text and data work fine?  What model phone are you using?  Is it VoLTE compatible with Public mobile network?
Maybe try to reboot your phone.  You can also try network reset of phone (note: this will erase any saved Wifi passwords)
slusagm
slusagm
What phone do you have?
Did you try Reboot phone and Reset Network Settings?
