Help
Amanda0697
Need help with sim card ans esim on one divice
Meow
You will have to provide more info to describe what is bothering you.
@Amanda0697  so you just want to switch from physical sim to eSIM ? If so log into the PM App with phone and buy eSIM and your number will be in the eSIM . Personally I prefer physical sim less hassle and much easier to switch devices just take old sim card out and put into new phone or any device without having to go online and mess around .
adding @Amanda0697  you can’t have the same number on both eSIM and physical sim at same time has to be one or the other unless you have two separate phone numbers
Amanda0697
How do i do that and how do i put my old number on my esim
@Amanda0697  Check phone settings sim
manger and enable the which ever sim you want to use as primary
