Help
07-17-2024 08:26 PM
07-17-2024 09:16 PM
Chat says its supposed to be within 30 minutes. I really hope that it's not until tomorrow, that's ridiculous.
07-17-2024 09:16 PM
They work late though so expect a response from them
07-17-2024 09:15 PM
It could take 4 hours, but it’s possible that they will reply tomorrow.
07-17-2024 09:13 PM
I have sent a message to CS Agent. It's been over 45 minutes with no response.
07-17-2024 09:12 PM
If you are getting
{"message":"Unauthorized"}
send a message to the CS Agent through the following link
07-17-2024 09:05 PM
How do I verify my account ownership? Which instructions?
07-17-2024 08:58 PM
Account compromise: If your account is locked or restricted, it may be due to suspicious activity or a violation of the terms of service. Verify your account ownership and follow the instructions provided to restore access.
Malware or unauthorized access: In some cases, account locks can be caused by malware or unauthorized access. Run a thorough scan with your antivirus software and ensure your device’s security is up-to-date.
07-17-2024 08:46 PM
Error says unauthorized. Chatbot says to contact support via private message. I’m not aware of my payments not processing, but even if so, there’s no way for me to login and check.
07-17-2024 08:39 PM
Even if your service is stopped, you still be able to login, what is the error when you login?
How long has you service stopped? When was the last time you pay your subscription fee?
07-17-2024 08:31 PM
Yeah I don’t have access to another phone. Not helpful.
07-17-2024 08:30 PM
cos you need to call that 1855 number using another phone!!
and did you recall a payment from your credit card?
07-17-2024 08:29 PM
Hm when I dial it just says call failed! And when I try to log in it says contact customer service…so I’ve sent a private message I guess that’s all I can do?
07-17-2024 08:27 PM
if you call 1-855-4PUBLIC and check your account status, does it tell you your account is suspended?
maybe you can buy a voucher and pay using voucher to get the account back first
