Help
Tom39
I can't get in to profile can't make a payment and my phone is due
2 REPLIES 2
@Tom39
PM just changed to a new EverSafe login system and you need to complete the setup
Do you know if you ever complete your EverSafe login?  You can get that working without support's help
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If you have not created an EverSafe id yet,  you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS.  (Sending the code to email would not be a choice until  EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support and have them to help in this situation:
Private message CS agent at
@Tom39  Hit resend couple time do you not get option for email . You can also get payment vouchers and load the 611 . If you need further help from support please
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
