11-17-2016 01:43 PM - edited 01-04-2022 01:13 PM
Can you please help?
Thank you so much.
12-03-2016 11:09 AM
11-21-2016 05:15 PM
11-17-2016 02:20 PM
no trying local numbers as well as numbers within the province do not work. Just a guess this is a bug while changing plans. Hopefully they reply soon. I have not had service now in 3 days since the plan renewal/change even though there are funds in the account and the plan seems to be active
11-17-2016 02:16 PM - edited 11-17-2016 02:18 PM
You will probably need to have a mod adjust, follow the instructions here to msg one of them. Changing plans seems to have bugs; mine did and they fixed it in a few days.
As for the phone saying you need an addon, are you trying to call a phone oustide of your home province? if that is the case you will need an addon as that counts as a long distance
