07-10-2025 04:54 PM
I just got my sim in the mail and finish creating an account and put the sim in my phone. Voice calls and texts work but mobile data doesnt work. Can someone help me fix that?
07-11-2025 06:45 PM
@tonisage I went to a different location(a couple blocks away) and did a speed test and got 30mbps. I don't know if that's a good or a bad sign.
07-11-2025 06:33 PM
@Loucid I think it's setup well since you can access the internet now. have you tried your speed test in an open space (not in your home)?
07-11-2025 12:14 PM
@hTideGnow yes the download speed is 7mbps. I thought that was too slow. I'm in new west(a city close Vancouver). I'm on the 5g plan tho my phone only supports 4g. It's a Xiaomi Poco x3 pro
07-11-2025 12:11 PM
@tonisage I haven't tried checking the speeds from a location yet. I wanted to make it was working properly before I did that. I will try that next
07-11-2025 08:58 AM
hi @Loucid
you can only get 7Mbps ? where (city) you are at?
and what plan you have?
and what phone you have?
07-11-2025 06:22 AM
@Loucid you should get close to 100mbps. Depending on your location, I had 51mbps now while in transit.
Have you tried checking a different location?
07-10-2025 07:53 PM
@tonisage I can do 200mbps on my home wifi. I know it's not the same thing but there shouldn't be 193mbps difference.
07-10-2025 07:51 PM
@tonisage it says 4g. It should be higher then 7mbps?
07-10-2025 07:43 PM
LTE or H+, which one are you currently on
07-10-2025 07:40 PM - edited 07-10-2025 07:42 PM
It's neither an iPhone nor a Samsung. It's an unknown brand called Tecno😎. It lacked the required band to work with PM
07-10-2025 07:18 PM
I tried using the apn settings you suggested. It does connect but it's does like 6mbps and thats way to slow
07-10-2025 07:12 PM
@tonisage what phone your family has?
07-10-2025 07:05 PM
Also regarding my family member, he was stuck on 3g, he could make calls and text but no data. After inputting the APN, THE Telus rep at Cambridge center mall said the phone isnt compatible with the network.
07-10-2025 07:04 PM
I will try that and I'll let know you if it works for me or not
07-10-2025 07:01 PM
A family member of mine had the same issue and this was the response from a customer care agent 2 days ago*
Hello,
Below you will find the updated APN to access our network.
Please reset the existing apn profiles and create a new one with the details below.
APN: SP.MB.COM
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
The APN is case sensitive, therefore we recommend to enter the settings exactly as displayed and make sure there are no spaces included.
Michelle
CS Agent Public Mobile
07-10-2025 05:31 PM
I don't think that's the right apn because now I'm h+ and not 4g
07-10-2025 05:23 PM - edited 07-10-2025 05:24 PM
If your phone is an Android. You will need to check the APN settings.
https://productioncommunity.publicmobile.ca/t5/Get-Support/APN-Settings/td-p/1089040
If you are still having issues dm a CS_Agent to help you.
07-10-2025 05:21 PM
Yes I can call and receive voices and send and receive texts messages, but data isn't working
07-10-2025 05:20 PM
I picked a new number. I did reset my network settings and I rebooted my phone. That didn't solve the problem. Any other suggestions?
07-10-2025 05:07 PM - edited 07-10-2025 05:09 PM
Did you port your number over from another carrier? If so, did you reply with YES to the text from your old carrier confirming you are porting your old number over to PM? You have 90 to reply. You will need to contact a CS_Agent to complete your porting by clicking on the Chat icon and type in Submit a Ticket.
Or did you pick a new number? If you did then reboot your phone by powering off then back on. If that didn’t work then reset the Network setting on your phone.
07-10-2025 05:06 PM
When you say 'voice calls and texts' work do they work both way? Can YOU call and text somebody and receive calls and text from somebody at your chosen (or ported in) number?
