04-08-2024 04:46 PM
Hello
I transfered to public mobile a few months ago but I am having issues with my calls breaking up or my voice goes roboty when I talk to someone on a cellphone (not a landline). I also had calls drop at times. My phone is only a few months old and is a OnePlus 12. It's just odd that it works fine with calls with landlines.
I have read lots of help posts here and on the internet, but nothing seems to fix it. I'd really prefer to not have to go back to my old provider but I do need reliable service. I am hoping someone here might know the fix. I have messaged public mobile for help but no reply yet.
Things I have tried
Rebooting phone
Switching calls to 4g or less and 3 g or less (that was worse)
Manually setting my network as public mobile 4g rather than letting it auto detect
Making calls with data turned on
Looking through the phone options to try to find the issues.
Please let me know if you know something that might help so I don't have to change phone companies again.
Thanks!
04-21-2024 05:41 PM
Little update in case it helps anyone. I talked to someone in support and the issue seems to be that there is a tower near me, but my phones instead log into a tower 2 km away because the close one is on the wring side of my building. Apparently it's fairly line of sight for ability to access it. So that's why my call quality is so poor and drops. Also apparently the towers in my city are overtaxed and struggle to keep up with demand in general as our population grows.
Options:
I could buy a signal booster for my place
I could turn on wifi calls, but that doesn't seem to work and isn't a service public mobile has (I just get a Telus message about an unexpected error)
Change providers again to one that gives me good signal at home.
04-13-2024 09:00 PM
With the galaxy 24 ultra I would sound roboty and then they couldn't hear me at all, but I could hear them perfectly. All the microphone diagnostics said they were working well and had no issues using the mic in VoIP calls. A factory reset did not help for that one.
For the OnePlus 12 I go roboty and can't be understood, but they still hear that I'm talking. I can hear them getting garbled as well at my end. It's more that one person who is having troubles hearing me so shouldn't be a sister l speaker issue. Doesn't happen on calls to landlines. When I tried 3g only it seemed worse. Which is the opposite of what should happen...
Thank you!
04-13-2024 08:52 PM
hi @Cerval when you said it didn't work, you meant just the voice breaking up but the phone actually connected?? you tried using headsets to confirm not the speaker issue?? and try changing the network mode to 3G only, not sure if your problem from VoLTE
04-13-2024 08:50 PM
Hi everybody. Thank you for answering. It's still not working properly but I thought I'd add new things I've tried in case it helps anyone think of the solution
They did refresh my service but it did not help
Turned off background noise cancellation (might be worse will while I do things)
Turned off ok google
Have tried changing to 3g or less and rebooting and same for 4g
Reset my network connections
What is it odd though is that it hasn't worked properly in a brand new Samsung galaxy 24 ultra or a brand new one plus 12. I did check before purchasing and both phones should work with public and I see people posting that it works well. But back to back issues in two new 2024 phones is sus.
Tried my sim card in galaxy 20 and so far no issues.
Will borrow someone else's card to put in my phone to try that next. Any other ideas?
Thank you for your time!
04-08-2024 05:01 PM - edited 04-08-2024 05:07 PM
Welcome to public mobile!
But it sounds like you did pretty much everything already. We personally have not had these issues that you've described, however, I do know that it's common based on previous complaints. Other option would be checked if you have an update pending. Finally, the last thing I could suggest but I don't know if you want to do. That is factory reset.. which would wipe everything from phone.
But wait until they reply to see what they advise.
04-08-2024 04:53 PM - edited 04-08-2024 04:54 PM
Hello @Cerval
That has always been a problem with Public Mobile. You just need to create a ticket and ask them to reset your network.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
04-08-2024 04:53 PM
@Cerval I’ve been with PM since 2018 . My phone account has voLTE and I still get this . To me it’s normal and I’ve put up with it for the fact we used to have low cost plans . Some will say this is not normal but I’ve grown used to it for 5+ years . Don’t think there’s much you can do
