Help with an agent
05-28-2022 07:56 AM
Hello can an agent please just kindly take the time to please help me for heavens sake with my data add on i just want my refund its been 4 days now worst service ever.
Add-Ons
05-28-2022 11:39 AM
Great, so it has been resolved then? Or you are waiting for confirmation?
05-28-2022 10:23 AM
Hi @Skyehigh1 it is good. So you will take the refund ?
05-28-2022 10:21 AM
Yes thats my case & an agent offered a solution yesterday what you suggested or a full refund.
05-28-2022 10:06 AM
@Skyehigh1 Have you checked your private messages for updates from the CSAs? Click the tiny envelope beside your avatar.
05-28-2022 09:25 AM
Hi @Skyehigh1 , do you still have problem with yesterday's issue about cannot reply? If you really cannot reply to CS agent's response, use this link to message them and remember to include the ticket number in the subject:
05-28-2022 09:17 AM
Can you share a little more? What the exact issue is? Have you been in touch with customer support? We can help explain, show you how to do certain things or get you customer support from an agent but we need some feedback from you to do so.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-28-2022 08:43 AM
@Skyehigh1 - what type of addon are you having an issue with?
If you still see the funds in your Available Funds balance, then you really did not successfully add the addon to your account yet. So if this is the case, you do not need to ask for a refund, as those funds will be used for future renewals or other purchases.
If you purchased an addon successfully in error, or one didn't work (for example a US roaming one), then perhaps you could explain this to CSA and submit a ticket via the link provided by @iliketotalk .
05-28-2022 08:19 AM - edited 05-28-2022 08:21 AM
@Skyehigh1 buying an add on is a two step process first you need to put funds in your account then go back in a purchase add on if you have done this you will need to open a ticket through Simon to speak to a customer service agent they will help you Click here
