Help, When I log in I'm am directed to weird dos promt.
Benjamin007
The dos promt looks as follows:
Pretty print [ ]
{"message" : "Unauthorize"}
I've changed my password and have also tried logging in on different devices.. Same thing. I've never had such a hard time trying to give a company money before.
Benjamin007
Yes, the PM app is working. Thank you all muchly.
Benjamin007
I will check that option, thank you.
hi @Benjamin007
the My Account is currently down for issue
but you might be able to login using the PM app. Please first update the app and login
@Benjamin007  Your not alone the website is down , but the PM app is working you can access it instead
but since you changed your password if you still can’t log into app get support to help @Benjamin007  if needed
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
