Help!!! My new actived number currently only can call out.
helen8988
Help! My new actived number currently only can call out.
Issues are
1. Cannot receive call.
2. Cannot send sms out.
3. Cannot receive sms
12 REPLIES 12
helen8988
thanks softech! CS Angent resolved the issue.
@helen8988  so, if you tried on different phones, you did a sim reseat and it still not working then.
At this point, I think you really need to open ticket with PM Support, they can reprovision your sim/account and that could resolve the issue
If you have not done so, these are the two ways to engage PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
helen8988
I restarted many times of my phone, and also tried different phones. Al same
@helen8988  - have you restarted your phone with the public mobile sim card in your phone yet since activation?
It would not be a bad idea to perform a reset of the device's network settings also upon changing providers.
@_joe - try above also.
@_joe please check your Community Inbox
_joe
Can I please get the number as well. Having the same issue. Thanks
@Outdoorsman wrote:
@helen8988 hi did you just activate an account and transfer your old number ? it sounds like you didn't leve your old sim in to receive tansfer request , you have 90 minutes to reply yes,I will send you the number to call to reinitiate your port request
If know that if the customer hadn't ask for a new phone number and asked for a number to be ported in , there could have been a porting issue, but a such an issue wouldn't have cause the failure of outgoing text messages.
helen8988
No. It's a new sim card ordered from publicmobic.ca and enabled online with a new number.
@helen8988 ok you may have a provisioning issue with your account you
need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
helen8988
No, this a new number. And I enable it on August 24. The first a few days are normal. Just found the issue in 2 or 3 days ago.
Meow
Did you request transfer number when you open account?
Outdoorsman
