Help! Just Signed Up
PrettyPrincess1
I just signed up for PM.  When I click “cellular” on my phone it says “Primary” and “Personal.”  I can’t send iMessages.  Any help is appreciated.  Ibhave no clue what this means.
snap-crackle
It means you have 2 SIM cards in your phone (1 physical / 1 eSIM, I'm guessing). Disable your old one or remove it after you've successfully ported your number to Public.
MissCanadiana
I had that problem when I first made the switch too! Did you do eSIM? I turned off my old SIM card (I haven’t removed it yet and I did eSIM for public mobile) and then disabled and re-enabled iMessage. I also made a few phone calls to the numbers I wanted to message (it says last phone line no longer available) and then I picked the new one and it eventually resolved itself within the next hour.
Randi3
I have the same question. I hope someone alswers
PrettyPrincess1
I CAN NOW SEND IMESSAGES!
Just wondering about the personal and primary now.
