Help I cannot receive any phone calls
Deeschmizz
When called it says I'm not set up to receive phone calls. And if I go into supplementary services this is the error I get.
Timer
@Deeschmizz
do rebooting device or factory reset, but you need to back up first.
@Deeschmizz   But you can make outgoing calls?
Which plan are you on now?
did you login to My Account and it shows account Active?
Deeschmizz
no
LindaBird
My only suggestion would be to turn your phone completely off, wait about a minute and turn it back on.
good luck!
By any chance, are you on one of the old data-only plans?
