04-12-2019 04:22 PM - edited 01-05-2022 04:20 AM
Hello,
I am trying to port my koodo number and everytime I click the add ons tab it says 'oh no! It looks like something went wrong...' I have tried logging in again as suggested but I get the same error message. The other tabs all seem to work fine. I think I need a moderator but I am not sure.
Any help is appreciated!!
04-16-2019 10:40 AM
Ive also been having the same issue. Have tried different browsers and nothing is working.
04-12-2019 05:37 PM
@MrsMagoo wrote:Thanks geopublic! I was able to do it through another browser. It said it was successfully done, now I just have to wait for it to come through. It took about an hour on another account. Fingers crossed.
thanks again all.
Great stuff!! Yes, Koodo postpaid ports don't take very long to complete.
Take care.![]()
04-12-2019 05:34 PM
thanks again all.
04-12-2019 05:17 PM
PM self-serve portal is very slow right now. If you still have problem accessing
[Plan and Add-Ons]--> [Change Phone Number] --> [Transfer a wireless or wireline number ]
Try again in an hour.
04-12-2019 05:09 PM
@MrsMagoo wrote:Ok, thank you. I will give that a try. Hopefully it is just a glitch.
I just tried accessing Plan and Add-ons and it works now. If you are still having issues accessing it do you have another browser installed on your computer that you can try?
If not maybe clear the cache and try again.
Hope it works.
04-12-2019 05:01 PM
Thanks, I already tried that. No dice...
04-12-2019 04:54 PM
On Overview page, try click on "View My Usage" link. This also opens other tabs under Plan and Add-Ons, including Change Phone Number tab you need to port your number over.
04-12-2019 04:52 PM
04-12-2019 04:50 PM
Hi, yes I know, but I have to click the plans and add ons tab to get to that point. Every time I do it gives the error message. I tried going through another link which let me get to the bring your existing number over but when I entered it and went to click check availability it booted me back out again.
04-12-2019 04:48 PM
@MrsMagoo wrote:Hello,
Looks like Addon & Plan feature on selfserve is down. That happens once in a while if you wait and try accessing later it should be back up and running.
04-12-2019 04:44 PM
@MrsMagoo, if you are trying to port a number, you need to click on change number. The add-on tab has nothing to do with number porting. If the number resides in Koodo post paid, then the porting can be done in the self serve. If it resides in Koodo prepaid, moderator team assistance is needed.
04-12-2019 04:43 PM
Hi,
Thanks for your response. It is not a prepaid account with koodo
04-12-2019 04:42 PM
@MrsMagoo wrote:Hi,
Yes, I got a sim and activated on public mobile with a temporary new number as suggested in other posts. I am now trying to port my Koodo number over. Currently both numbers work with their respective SIM cards. I can log in to self serve but keep getting the error message when I click the add ones tab.
Is that a prepaid Koodo number?
04-12-2019 04:41 PM
Hi,
04-12-2019 04:36 PM
@MrsMagoo If it's prepaid Koodo you'll need assistance from the moderators to facilitate porting. Send private message to moderator_team and ask for assistance. Sometimes it can take a few hours to hear back from them though. Good luck!
04-12-2019 04:34 PM
I am trying to port mykoodoo number andeverytimee I click the addonss tab it says 'oh no! It looks like something went wrong...' I have tried logging in again as suggested but I get the same error message. The other tabs all seem to work fine. I think I need a moderator but I am not sure.
Did you successfully port yourKoodoo number to PM number? And is your
account actived?
