04-22-2026 02:56 PM
my esim is not giving me internet and i cannot place any calls , its been working perfectly since i had it but today suddenly is not working anymore. is installed corectly so no worry about that. pls send me a new sim card or make it work.
04-22-2026 03:06 PM
iPhone 13 should be good
try Reboot the phone and Reset Network Settings
if that does not work, the best way is to get a new eSIM for free (esim owners can get a new one for free every 15 days). Go to PM app -> Account-> Purchase sim card and buy eSIM. The system should not charge you
and you if you want to change to physical sim, it is not free, you have to buy one yourself for $10
04-22-2026 03:05 PM
try rebooting your cell. After that, try a network re-set. See if that helps and let us know either way.
04-22-2026 03:00 PM
im in ontario , using iphone 13
04-22-2026 02:59 PM
are you in Manitoba and what phone you are using?
