06-28-2017 10:54 PM - edited 01-05-2022 02:18 AM
06-29-2017 12:31 AM
06-29-2017 12:29 AM
@EltonB what was the issue? I see you posted the issue was solved.
06-28-2017 11:21 PM
@mimmo wrote:
Typically I would say these are the most common data related issues apart from APN settings
1) have you looked if your data addon is listed in the addon section, ie did you accidentally use it all up.
2) what does your plan details say
3) is data turned on
4)can you try sim in a different phone.
I know when my help is not needed, don't waste time on this guy. Let him be. The moderators are not going to help him with APN settings given the volume of activation problems on their plate.
06-28-2017 11:16 PM
06-28-2017 11:13 PM
06-28-2017 11:08 PM - edited 06-28-2017 11:10 PM
@EltonB, double posting is of no use. In fact it is disruptive as if telling the moderator team to look in many places for the same customer issue. Generally, you post here if you have a non account related problem. The folks here are very helpful. For account related problems, only the moderator team can resolve them and so go the private message route. Your problem appears to be non account related. If you have had data working before then it is not account related. If you can be more descriptive, the community might be able to offer a focused solution.
06-28-2017 11:08 PM
