09-21-2020 10:57 PM - edited 01-05-2022 01:18 PM
Hello - I am not able to receive calls, though I can make calls; tried the usual rebooting/ restart; no. is new. Tips/ suggestions welcome.
09-23-2020 08:55 PM - edited 09-23-2020 08:55 PM
@abhilasha21 wrote:Check the settings :
Go to the settings on your phone > More > Mobile Networks > Access point names
Press the Menu, and select New APN
Input the following information, on each field:
APN: sp.mb.com
Please realize that making changes to APN setting cannot make placing or receiving phone calls possible. APN settings don't have anything to do with phone call capabilities.
09-23-2020 08:35 PM
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC: http://aliasredirect.net/proxy/mb/mmsc MMSC Proxy: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
restart your phone and test calling your number.
please contact the moderator if this doesn't work.
09-22-2020 10:28 AM
You can wait for the moderators to get in touch or you can change the number yourself from within your account.
09-22-2020 10:11 AM
Hi, thanks.
the no. for this phone is already assigned. So able to make calls; but not able to receive calls. On calling it says 'not in service"
09-22-2020 10:10 AM
Hi, thanks.
the no. is already assigned. So able to make calls; but not able to call. On calling it says 'not in service"
09-22-2020 02:42 AM
I think @LovesToPM nailed it on the head. If you chose a new number at activation and its been this way since that time then accidently assigning a phone number already in use is not unheard of. Calling it and hearing the outcome can confirm it for you. Once confirmed if this is your first and only number you've had since activating your sim card you will have no issues changing your number within your account. If you feel more comfortable waiting for a moderator to confirm this is ok too.
09-22-2020 01:11 AM
Hi @majomon
Try calling your number from another phone (maybe in the morning if it's late now).
If someone else answers your call or your call goes to someone's else voicemail, then the number is already in use and there was a glitch when the new number was assigned to you.
If this is the problem, logon to your account and change your phone number. You are permitted to get a new number once every 30 days.
09-22-2020 01:01 AM
@majomon wrote:Thanks for the reply. Tried this out; but still n/w. Waiting on moderators...
What does the caller get when they call you? (or you call your number from another phone)
Perhaps the phone is on do not disturb. Check your settings.
Perhaps it's on call forwarding all to somewhere. Check your settings or dial ##002# to reset.
Perhaps you blocked calls from whoever you're testing getting a call from. Check your block call settings.
09-22-2020 12:24 AM
@gpixel his number shows in the title of your post.
09-22-2020 12:23 AM - edited 09-22-2020 12:26 AM
Oracle's / retired Oracle. Merge this thread to thread below. Thank you!
@computergeek541 @Luddite @ShawnC13
EDIT - Thanks PCgeek👍
09-22-2020 12:22 AM - last edited on 09-22-2020 12:24 AM by mimmo
@majomon maybe you should read through the community guidelines to protect yourself
09-22-2020 12:21 AM
@majomon please edit your post and remove your number from the title as this is a public forum and everyone can see it.
On your post right side click the 3 dots and select edit post.
09-22-2020
12:16 AM
09-22-2020
12:22 AM
computergeek541
Thanks for all the care and tips. As of now I am still waiting for the phone to be able to receive calls...
edited by computergeek541: removed phone number
09-22-2020 12:14 AM
09-22-2020 12:13 AM
tried this out; n/w. waiting for moderators to respond
09-22-2020 12:04 AM
@majomon Power off your phone. Remove the sim for 5 minutes reinsert the sim power up and test again.
09-21-2020 11:46 PM - edited 09-21-2020 11:47 PM
Are your calls going to voicemail? Log into your account. Suspend your service via lost/stolen. Log out. Wait 1 min. Log in. Unsuspend. Log out. Reboot. Test. Have someone call you.
09-21-2020 11:24 PM
@majomon if it's still not working your account likely did not provision correctly. You'll have to contact moderators to fix the issue. See my earlier post with instructions on how to reach them.
09-21-2020 11:22 PM
tried; still n/w
09-21-2020 11:20 PM
Thanks; will check these out.
09-21-2020 11:14 PM
@majomon try resetting your network settings
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
09-21-2020 11:13 PM - edited 09-21-2020 11:14 PM
@majomon thank you for the answers. I gather you selected a new number at signup.
You can try putting resetting your network settings. If that don't work try putting putting phone on airplane mode for 5 minutes. If it still don't work. Plug the phone into iTunes and see if it pushes any updates to the phone.
If none of those solve the problem your account may have not provisioned correctly and you will need to speak to the moderators to fix your account. Two ways to reach them.
1-
2- if you're having trouble opening a ticket through the chat bot. Send them a private message at this link.
Also if you used a referral code when activating your SIM card for a $10 signup bonus. The credit will be applied to your account within 72 hours.
Welcome to Public Mobile 🙂
09-21-2020 11:06 PM
We will need more details please.
What kind of phone? iPhone 6
What plan are you on? 25$ unlimited
Are you a new client? Yes
Did you just port your number from another provider? No
If you did how long ago did you port? n/a
Who did you port from? Cell can take a few hours to 24 if all information provided was correct. Landlines may take 7 days. n/a
What else works on the phone? Text in and out? Data? Text is working. Data is working
If you did just port. Use old sim card from old provider you may be able to receive calls in there until the port is complete. n/a
09-21-2020 11:00 PM
What kind of phone?
Let us know.
