Having trouble
C-Rock1
New subscriber, having issues no connection to network it been 7 hrs. Purchase ESIM and followed instructions to activate. Still nothing. Not sure what to do. Any ideas...
1 REPLY 1
hi @C-Rock1
the esim probably is installed and just not configured properly
you might first make sure the old carrier sim is removed or disabled if it is an esim
And Go to Settings-> Cellular or sim manager and make sure the Public Mobile esim is there and enabled (or Turn on this line option is enabled) and set as Primary. Then Reset Network Settings.
In case you don't see a Publc Mobile esim there, check the Welcome email from PM and there is a QR code to scan and install the esim
If you still need further help,  ask support agent .  You can submit  ticket by direct message:
