Having problem recieving calls and txts
04-02-2019 03:34 PM - edited 01-05-2022 04:07 AM
I just change to public mobile SIM card. I can make calls, but I couldn’t receive calls or msgs. @Moderator Team
Phones
04-07-2019 09:34 PM
@graceguo950730 wrote:Hi,my old cycle has ended. But I still have problem receiving calls and msgs.
Hi @graceguo950730 , use the link (in orange) that @RobertQc provided to send a message to the moderators (if you haven't already done so). Explain to them the problem you're having with porting in your number from the other carrier.
04-07-2019 09:30 PM
04-02-2019 03:40 PM
@graceguo950730 wrote:It’s ported in. So I should use my old SIM card until this cycle is over?
@graceguo950730Yes, use the old sim till it stops working, then the new sim card should be working 100%. If it stops working and the new one does not work or been more than 48 hours then message the mods
04-02-2019 03:38 PM
04-02-2019 03:36 PM
@graceguo950730, is this a new phone number, or a ported in number?
If ported in, continue on old sim until it stops working. If it's a new number, try restarting your phone.
04-02-2019 03:36 PM
@graceguo950730 Also you should also be able to stick your old sim card in and still works, keep using it until it stops working, then your new public mobile sim should have incoming calls working
04-02-2019 03:35 PM - edited 04-02-2019 03:35 PM
@graceguo950730 wrote:I just change to public mobile SIM card. I can make calls, but I couldn’t receive calls or msgs. @Moderator Team
If you just ported that is normal, it takes some time, every hour or so remove your battery / restart your phone. It can take time on your first port over and there can be weird issues for a short period of time.
If the issue continues you may have a partially completed port but most often ports just take a bit longer. One of the moderators can take a look, see if they need to do something to move it along. Click this to send them a message
