Having error when trying to subscribe
shuaib2s
Hi,
I am trying to join PM again and got to the payment stage. My phone and IMEI is compatible but when I go to put in my payment info etc I get this error M.8702(see photo attached). FYI, I was a PM subscriber in the past.
thanks,
Salman
slusagm
check this:
https://productioncommunity.publicmobile.ca/t5/Announcements/Open-Issue-Flash-Sale-Promo-Activation-...
if you were not charged, it is ok
if you were charged, then ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Sansan
There is an announcement on the website that states that they have indicated they are experiencing system glitches right now.
I would wait until tomorrow to try again.
hi @shuaib2s
this is an active issue that PM is aware and  trying to fix, i suggest you to wait till issue is fixed before trying again
