04-24-2026 06:51 PM
I accidentally began to activate eSIM for the wrong phone, giving the EMEI number for the wrong phone. I have not activated the eSIM on the wrong phone. Can I login with the correct phone and continue the activation process?
04-24-2026 07:24 PM
04-24-2026 06:58 PM
the IMEI you provided is for porting, not for eSIM installation. In fact, for porting, we suggest using account number of your old provider instead
with the wrong phone for eSIM, yes, you should have installed the PM app on the phone you want to install the eSIM. I think PM can help, please send them a direct message
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
