a month ago
I ported my number on Thursday when I changed my service from Lucky to Public. Now, iMessage will not work with my phone number, and I have tried everything to fix it.
I’ve tried:
-restarting my phone, with iMessage off, on, and all various formats
-resetting network settings and restarting my phone
-checking that my numbers are correct in settings, and then resetting the iMessage switch
each time, I’m met with the “error during activation” message, which from my own research should mean that it’s a carrier problem?
is there anything I can do?
4 weeks ago
Turns out it was an issue on Public’s end. All I had to do was wait for them to reauthorize my number, as I brought the same number from my previous carrier and it glitched the system a little. All is well now however.
a month ago
I’ll try that and let you know if it works
a month ago
hi @DebSpencley
you need to clearly re-register iMessage.
go to Settings, Phone, My Number menu and remove the phone number manually
Wait 15 minutes and reboot the phone. Then go back to the same menu to manually put the phone number back to re-register iMessage. It might take some time, just wait
