HELP. Invalid sim
07-11-2019 11:10 AM - edited 01-05-2022 08:17 AM
Can some one please help.. service was renewed last week. My daughter called her phone is saying invalid sim.. Please help.. this will be her second month with public mobile
Service
07-11-2019 12:27 PM
How was the phone unlocked originally?
I'm thinking the phone was dropped and the SIM got mis-aligned and would just require a re-seating of the SIM.
If you paid for a cheapie service; sometimes, iPhones can get re-locked by the original carrier.
07-11-2019 12:20 PM
The services could need to be reprovisioned. Try logging into My Account, mark the phone as lost or stolen, then undo the lost or stolen phone, then try restarting.
Or, the SIM could be improperly installed, try removing it and putting it back in.
Or the SIM is damaged and you might need to buy a new one. Try contacting a moderator to see if they can help by shipping a new one.
Good Luck!
07-11-2019 12:05 PM
I will try to look at it tonight thank you everyone!
07-11-2019 11:51 AM - edited 07-11-2019 11:51 AM
@AngeMeuNo there is no free SIMs. You can activate a new SIM in your daughter's selfserve account.
HOW TO CHANGE YOUR SIM CARD #
07-11-2019 11:46 AM
Just incase is there free replacements for Sims? Also how would I activate a different sim on her profile?
07-11-2019 11:29 AM
07-11-2019 11:25 AM
Even though it worked for a full month on PM? she is only 13 so I'm trying to figure this out while I'm at work
07-11-2019 11:24 AM
@AngeMeu wrote:I cant her sim is smaller then mine I am also at work😔 do I seriously need to buy another sim??
Since your SIM is larger, probably a Micro, versus her Nano in the iPhone, before buying another SIM, as a last resort, see if she can try her SIM in any other phone with the same SIM type... Maybe a friend or other relative, just to 100% prove it's the SIM.
Good Luck
07-11-2019 11:22 AM
From what you described it sounds like your daughter's phone either got locked to a carrier (unusual) or got added to the blacklist. Either way if your daughter is capable she can always walk into her nearest Apple Store to get it figured out.
07-11-2019 11:21 AM
to further @GinYVR if you get the message with her sim in your phone she will probably need a new sim) and also try your sim in her phone and see what happens.
what you are trying to do here is isloate hardware(phone) vs sim issue.
07-11-2019 11:18 AM
07-11-2019 11:17 AM
@AngeMeu wrote:Can some one please help.. service was renewed last week. My daughter called her phone is saying invalid sim.. Please help.. this will be her second month with public mobile
Try turn off phone and take out SIM card, then waiting 30 seconds or more, put SIM card back, turn on phone.
If still have problem then need to conact moderator team for help:
07-11-2019 11:15 AM
@AngeMeuI would suggest swapping your daughter's SIM card with yours to see if the problem persists on her phone.
07-11-2019 11:14 AM
Iphone 6s.. not on black list was working great until this morning.
07-11-2019 11:14 AM
07-11-2019 11:13 AM
