Got the wrong plan
Owen10
@CS_AgentI meant to select the $40 5G 30GB promotion that ended on Aug 28, 2023, but i selected the wrong plan. I tried submitting a ticket but the system showed me an error every time I tried. Can someone assist in resolving this please.
@Owen10
This is an offer that is offered for new members and not for existing members.
Did you just subscribe and activated a new SIM/eSIM? If you are a new member, just private message a CS_Agent to have it changed at:
Priority
If the Customer Service Agent isn't able to Change/Refund you for the Accidental Plan Purchase than just hold out and use it for the 30 days you've already paid for and schedule a Plan Change to the Plan you want within the 'Subscription & Add-ons' Section.
https://myaccount.publicmobile.ca/en/account/plan/change-plan
@Owen10  As others have said ask support if they can help you . That plan has been extended till sept 5 . Could always create a new account on that plan if they can’t help or consider the 40GB $45 plan for next renewal it’s only $5 more
@Owen10
not sure if support can help but you can try message them here :
LitlLdy
@Owen10 , it was an honest mistake. Explain the situation & hopefully the CS_Agent will change it for you. The plans promotion date was extended to September 5th!
The chatbot/virtual assistant is broken & has been for quite some time sorry! 😔
You can send a private message to a CS_Agent using the link: ->   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
  • Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox (envelope icon) at the top right of this page to the left of your community avatar on your computer or by clicking on your avatar on your device.
Edit: Typo in date!
