06-30-2023 01:57 AM
But your 'eversafe' is not working. It will not let me change my cell number from my old one to the new one. Still comes up with code to the old cell this is ridiculous as it eversafes people with public mobility accounts out. Obviously since it is the old number I cannot acces the code. Please either get rid of 'eversafe' and get a security system that works properly. Or get 'eversafe' to work! I can't even remove the check mark from my old cell and just use basic security of email listed. No option that work. I am really irritated to say the least.
06-30-2023 12:04 PM
yes, many have the same issue with community ID since this new system. It is a quick fix for PM support now, and you just need to open ticket to engage them:
06-30-2023 11:50 AM
Ok that is how I got in was to reclick the resend. But now since I have joined the community with my concerns and questions I have two eversafe ID the one under the name Matara53 needs to be closed or removed so I can use that cell number to change it on my original account mange eversafe. Could someone in tech close the Matara53 eversafe please?
06-30-2023 05:20 AM - edited 06-30-2023 05:24 AM
You can update both Email and phone number on EverSafe after you login. I tested that myself and worked. But YES, seems like there is a problem now and it is not currently working. There were at least 2 posts yesterday about the problem.
Have you open ticket with support yet? If not, message them to ask them to look into it
But as to the check mark, both have to be checked as it allows the system to send you to either one
And your email on EberSafe is working? You know how to ask the system to send 2FA to your email instead of phone, right?
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
06-30-2023 02:00 AM
Added note my post was under a community account and not the one I subscribed to which is the one I can't access.
