Global roaming
schung
Is there a package for global roaming with Public mobile? I need to get text messages while in Asia.
7 REPLIES 7
LoveNature
Hi @schung
PM Roaming for the US only.
the best to purchasing from  Amazon: prepaid sim card asia
HALIMACS
Indeed @schung , we've found that device to device RCS services work quite well (i.e. iMessage and/or Android chat) when both parties have either Wi-Fi access or data availability.
Saves on purchasing add-ons or SIM cards in countries outside Canada/USA.
dust2dust
If you are using an iphone then you can instant message (this is NOT sms) between idevices simply connected to the internet anywhere.
A bunch more work would be needed to forward texts to the mentioned voip app if you are so inclined. But replying would then look like whatever number you're replying from...not the Public number...unless you can spoof your number.
Hi @schung no roaming in Asia
you need to use local data in Advance a, cheaper than roaming anyway.   Use VoIP like TextNow for calls and text
@schung PM only provide roaming options in US and no where elseso, no global roaming 😞
@schung  No sorry PM only has roaming for the US
