11-09-2016 01:03 PM - edited 01-04-2022 06:10 PM
Hi guys,
I switched from Koodo to PM a week ago due to the 12 gig promotion.
Unfortunately the data speeds I'm getting have been embarrassingly bad to the point that I can't take full advantage of the offer. I can't even watch videos without having to buffer the video for 1 minute. Even simple sites like reddit take about 10 seconds to fully load on LTE, which was never the case with Koodo.
My phone is a LG nexus 5 which I have used for 2 years, and I also followed the APN settings to the point.
Here are my last 3 speedtests:
0.02 up, 1.39 down
0.3 up, 2.24 down
0.21 up, 3.69 down
The tests I ran last week were just as bad.
I really don't know what is wrong. At first I thought it was a Telus issue, since I'm very far from the closest tower (I'm near Downsview Airport in Toronto), but Koodo/PM are on the same network.
I really need help because these speeds are driving my insane.
11-09-2016 03:10 PM
I read on Wiki that before the speed 3.1 Mbit/s for downloads and 1.8 Mbit/s for uploads.
However, does anyone know what speed I should be getting?
11-09-2016 03:01 PM
From what I read you should be getting faster speeds.
Keep running tests throughout the day to get an average
11-09-2016 02:37 PM
I just ran the test. 8.63 down and 0.14 upload. is that normal?
11-09-2016 02:22 PM
Thanks but I ported a week ago. I thought I'd wait it out and here we are a week later with the same bad speeds!
11-09-2016 02:17 PM
If you just port your number, you may need to wait for a while. I have LG G3 and when I ported my number from Kooodo to PM it took 15-20 and it was still on 3G instead of LTE. after that it switched to LTE but with low speeds and after couple of reset and 10 minutes it started to work
11-09-2016 02:08 PM
I know right? It's very confusing as the only thing I changed was provider/SIM cards.
I appreciate your help guys!
11-09-2016 02:06 PM
I have no idea then. Maybe a MOD's can explain this
11-09-2016 02:04 PM
@nishufan I never did an official test with Koodo because I never had any problem, but if I were to guess it would be about 20 mbp down.
Any video I picked would load pretty quickly, unlike with PM where it can take 30 seconds or so.
I guess I can try when I get home - it just doesn't make any sense how the speed would suddenly stink at work when they share Telus/Bell towers between Koodo/PM
11-09-2016 02:00 PM
11-09-2016 01:58 PM
@hung52 I'm testing at work, so the testing environment is no different than when I was with Koodo and had great speeds.
As for bars, its anywhere from 50% to 75%
It's just really weird how with Koodo everything was great and now with PM it's very bad. If they share the same Telus/Bell network, what is possibly causing the issue?
11-09-2016 01:53 PM
Also it depends where you are at. If your in basement... then thats why its slow. Otherwise how many signal bars do you get? If its like 1-2bars it explains why its slow.
11-09-2016 01:51 PM
@hung52 Yep I tried all that you suggested and the speed is still bad.
Even with LTE, my down is 6.6 and up 0.38
I'm honestly running out of ideas as to what to do!
11-09-2016 01:49 PM - edited 11-09-2016 01:50 PM
@nishufanYes I reset my network settings multiple times, no big difference at all
11-09-2016 01:28 PM
Try to remove the simcard and turn off LTE > reset network and restart your phone. Re-insert your the PM simcard and re-open the LTE.
Second option: Sometimes if you have a case/cover on your phone, this might be the problem. Try to remove the case/cover and see if the speed is going up. Also turn off your wifi while using LTE.
11-09-2016 01:22 PM
