06-03-2020 12:36 PM - edited 01-05-2022 11:00 AM
Hey guys,
I'm planning on buying two sim cards and activating those. Is there a way than the first account uses a referral code from the second account and vice versa?
When is a referral code created? After you create an account? Will that code be used only after the first person created an account meaning the first person will not be able to use the second person's account?
Joining Public
06-03-2020 12:51 PM
@antosha-85 Referral codes get generated after you activate your PM sim card so you will need a referral code for card# 1 in order to get the $10 one-time bonus.
06-03-2020 12:49 PM
@antosha-85 wrote:Hey guys,
@antosha-85, you will not be able to activate two SIMs and use each other as referrals. The referral code is not generated until you have an activated SIM. You will need a referral code from a family member or friend or someone who already has an active account. You would use their code with the first SIM activation and get a $10 credit (within 72 hours). You would then activate SIM 2 and use the referral code from SIM 1 to get the $10 credit on that account.
06-03-2020 12:45 PM - edited 06-03-2020 12:52 PM
Here is more info about the referral award.
https://www.publicmobile.ca/en/bc/get-help/articles/the-refer-a-friend-reward
06-03-2020 12:39 PM - edited 06-03-2020 12:41 PM
You'll need a referal code from a family member or friend who already has a PM account to activate card #1. Then when it's activated, you'll get an activation code from #1 to apply to #2.
